I'm not sure what they mean. Did you try Googling and researching for manuals or other information?
Message: 1134 |
Date: 5/13/2011 |
Subject: Re: KFLOP+KANALOG controlling Nanomotion |
Hi Tom, I think I may have found the answer on page 16, Fig 4 of the AB5 driver manual. Nanomotion Tech Documents 7th one from the bottom; " AB5 and AB51 Driver User Manual
" . ( Can't seem to put a direct link, it saves as an *.aspx extension) It shows a single ended Analog input connection to the driver/amplifier. So the Kanalog outputs are connected as follows to the amp; (Kanalog)GND -> (AB5) Vin(-) (Kanalog) JP11 Pin1 -> (AB5) Vin(+) Note: the GND at the AB5 Driver/Amp is connected to the Vin(-) at the AB5 end. Does this make sense to you? Thanks, Mark --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@...> wrote: > > Hi, > > I'm not sure what they mean. Did you try Googling and researching for manuals > or other information? > > Regards > TK > > > > > ________________________________ > From: bb_lazar bb_lazar@... > To: DynoMotion@yahoogroups.com > Sent: Thu, May 12, 2011 10:34:45 AM > Subject: [DynoMotion] KFLOP+KANALOG controlling Nanomotion > >  > I have some Nanomotion AB5 drivers for HR8 model Piezo motors. These have > control inputs which says the following in a table in the manual; > > > I/O Port Pinout(DB25 connector) > Pin1 -> Vin+ -> Input -> 0 to 10VDC Analog Control > Pin2 -> GND -> Ground -> > . > . > . > Pin14 -> Vin- -> Input -> 0 to -10VDC Analog Control > Pin15 -> GND -> Ground > . > . > > Where I assume the Grounds are all Analog Ground. > > How do I physically connect this driver to the Kanalog with AGND & AOut DAC > output on port JP11? > > Thanks >
Message: 1135 |
Date: 5/13/2011 |
Yes that looks correct to me.
Message: 1137 |
Date: 5/13/2011 |
Great. I got confused since the Kanalog doesn't have V+/V- control
signals that I have seen on other controllers.
So it's not strictly a differential voltage output control, and it has
to be wired like this to any amp with differential inputs I would
assume?
> Sent: Fri, May 13, 2011 12:21:25 AM
> Subject: [DynoMotion] Re: KFLOP+KANALOG controlling Nanomotion
> Hi Tom,
driver manual.
> 7th one from the bottom; "AB5 and AB51 Driver User Manual " . ( Can't
seem to
> put a direct link, it saves as an *.aspx extension)Â
driver/amplifier.
AB5 end.
> Thanks,
> Mark
> --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote:
> > Hi,
> > I'm not sure what they mean.ÃÂ Did you try Googling and
> > ÃÂ
have
AOut DAC
> > Thanks
Message: 1145 |
Date: 5/16/2011 |
Hi Mark,
Yes. The Kanalog DAC outputs are a +/-10V analog signal relative to its ground.
Message: 1146 |
Date: 5/16/2011 |
Tom, Thanks for clearing all that up. Just one more thing, the diagram I referred to has a shielded twisted cable connecting the controller and amplifier. Where can the cable shield be connected from the controller (KFLOP) side? -Mark --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@...> wrote: > > Hi Mark, > > Yes. The Kanalog DAC outputs are a +/-10V analog signal relative to its > ground. > > TK > > > > > ________________________________ > From: bb_lazar bb_lazar@... > To: DynoMotion@yahoogroups.com > Sent: Fri, May 13, 2011 7:03:24 AM > Subject: [DynoMotion] Re: KFLOP+KANALOG controlling Nanomotion > >  > Tom, > > Great. I got confused since the Kanalog doesn't have V+/V- control > signals that I have seen on other controllers. > So it's not strictly a differential voltage output control, and it has > to be wired like this to any amp with differential inputs I would > assume? > > --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote: > > > > Yes that looks correct to me. > > TK > > > > > > > > > > ________________________________ > > From: bb_lazar bb_lazar@ > > To: DynoMotion@yahoogroups.com > > Sent: Fri, May 13, 2011 12:21:25 AM > > Subject: [DynoMotion] Re: KFLOP+KANALOG controlling Nanomotion > > > > à > > Hi Tom, > > > > > > I think I may have found the answer on page 16, Fig 4 of the AB5 > driver manual. > > > > Nanomotion Tech Documents > > > > 7th one from the bottom; "AB5 and AB51 Driver User Manual " . ( Can't > seem to > > put a direct link, it saves as an *.aspx extension)à > > > > > > It shows a single ended Analog input connection to the > driver/amplifier. > > > > So the Kanalog outputs are connected as follows to the amp; > > (Kanalog)GND -> (AB5) Vin(-) > > (Kanalog) JP11 Pin1 -> (AB5) Vin(+) > > > > Note: the GND at the AB5 Driver/Amp is connected to the Vin(-) at the > AB5 end. > > > > Does this make sense to you? > > > > Thanks, > > Mark > > > > > > --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote: > > > > > > Hi, > > > > > > I'm not sure what they mean.Ãâà Did you try Googling and > researching for manuals > > > > > > or other information? > > > > > > Regards > > > TK > > > > > > > > > > > > > > > ________________________________ > > > From: bb_lazar bb_lazar@ > > > To: DynoMotion@yahoogroups.com > > > Sent: Thu, May 12, 2011 10:34:45 AM > > > Subject: [DynoMotion] KFLOP+KANALOG controlling Nanomotion > > > > > > Ãâà > > > I have some Nanomotion AB5 drivers for HR8 model Piezo motors. These > have > > > control inputs which says the following in a table in the manual; > > > > > > > > > I/O Port Pinout(DB25 connector) > > > Pin1 -> Vin+ -> Input -> 0 to 10VDC Analog Control > > > Pin2 -> GND -> Ground -> > > > . > > > . > > > . > > > Pin14 -> Vin- -> Input -> 0 to -10VDC Analog Control > > > Pin15 -> GND -> Ground > > > . > > > . > > > > > > Where I assume the Grounds are all Analog Ground. > > > > > > How do I physically connect this driver to the Kanalog with AGND & > AOut DAC > > > output on port JP11? > > > > > > Thanks > > > > > >
Message: 1147 |
Date: 5/16/2011 |
Hi Mark,
I think the best bet would be to tie the shield also to a Kanalog ground on the Kanalog end and leave the shield open at the amplifier end.
